i got engine codes for o2sensor heater circ bank1sensor2...
and no activity bank2 sensor 2 so would this be that both sensors need to be replaced? the codes were 1198 and 160 i already read the fault code page but what to do ?
also would it be ok to DRIVE the car 1000 miles with the codes like that? my grandmother passed away monday morning and the funeral is in lake charles la and mom is driving down hopefully today from kc thanks!!!!
Your engine will run on a default map, gas consumption will probably increase but for a short term there should be no harm.
Will deal with this when you get back.
is reported to have a heater problem while the second one is not reporting to duty at all (unplugged?)
Unless your MPG takes a steep dive where the car runs so rich it will plug up the cat there should be no short-term problems.
Have you ever replaced the rear O2 sensors? Is your mileage high enough to just go ahead and replace them?
But of course first make sure they're plugged in, etc ...
sensor for both banks. Quite possible that your local auto store has decent pricing on it (~$90 on the web).
Otherwise:
Bosch PN 13552 Oxygen Sensor - OE Type After Catalyst Right side
Bosch PN 13550 Oxygen Sensor - OE Type After Catalyst Left side
Considering your mileage I'd just replace both of them (or all four for that matter)
Otherwise:
trailertravis13
07-25-2006 04:40 PM
quickaudi:STFA
VAG-COM Discussion
02-17-2006 06:31 PM
