I have searched but can't find a tech article for chaning spark plugs in a 1.8t
Old 04-20-2005, 12:40 PM
Junior Member
Absolute Santorin's Avatar
Default I have searched but can't find a tech article for chaning spark plugs in a 1.8t
could someone be so kind as to help me out
Old 04-20-2005, 12:43 PM
Banned
ModifiedA4's Avatar
Default full article
<ul><li><a href="http://www.bentleypublishers.com/tech/audi/audi.b5.spark.plugs.replace.htm">link</a></li></ul>
Old 04-20-2005, 12:46 PM
AudiWorld Uber User
Solaris's Avatar
Default There really isn't a whole heck of a lot to it. Remove the engine cover, then pull each coilpack
I think you need a 6mm allen key (can't be certain of size, just make sure you have a metric set)&lt;it's a 5mm. Remove the 2 allen bolts for each coilpack, then use a spark plug socket (not sure of this size either) with an extension. There are torque specs for the spark plug installation (15 foot-pounds, I believe)&lt;wrong, it's 22, but I think you can just get away with cranking the plugs in tight. Not too tight, though, the head is aluminum.
Old 04-20-2005, 12:47 PM
S7
S7's Avatar
We have essentially the same setup: 0.030 gap works well.
Old 04-20-2005, 12:48 PM
iammatt's Avatar
Default that's funny, i searched too
cool article<ul><li><a href="http://www.fastaudi.net/a4/library/sparkplugs.html">http://www.fastaudi.net/a4/library/sparkplugs.html</a></li></ul>
Old 04-20-2005, 12:52 PM
Junior Member
thank you
Old 04-20-2005, 12:58 PM
FAQ Author
BSK auf Arbeit's Avatar
Default its not in the faq?
if nto someone add the ting!
Banned
ModifiedA4's Avatar
it is.
Old 04-20-2005, 01:41 PM
iammatt's Avatar
yo no speka da engrish?
Old 04-20-2005, 01:47 PM
FAQ Author
not really. i have a 24hr translator at my service
Quick Reply: I have searched but can't find a tech article for chaning spark plugs in a 1.8t
