I hear a light grinding noise from the brakes, even when I'm not applying them (more)
is that normal? it sounds like the brakes are lightly being applied, even when i'm totally off of them. is there such a thing as the distance between the pads and rotor being too small?
i've been reading the archives a bit, and I definitely have brake chirp (when you hit a bump, and you're not applying the brakes) AND when applying light braking pressure, i hear constant squeaking, like running your nails along the chalkboard.
I'm going to the dealer tomorrow. Are the 2 problems the same thing? i found the TSB on brakes, would that fix both problems?
Thanks.<ul><li><a href="http://www.20vturbo.com/tsb/mirror/audipdf/a460001.pdf">TSB</a></li></ul>
On old Coupe Quattro, I had a rock thrown up into the brakes and lodge between the rotor and brake shield. Similar hideous sound that varied with car speed.
So, turn off the computer, remove a wheel, and do some careful investigation. By rotating the hub by hand you ought to be able to pinpoint the location.
thewatcher101
03-05-2008 07:26 PM
CraigL
12-06-1999 12:49 PM
