I need 97 bose stereo wiring diagram.
Guest
Posts: n/a
I searched the archive but I can't find it. so any one got them please help!! I need it to install my Clarion 9375 headunit on a bose system with the bose amp. Anyone got info on that please help also... <p>Thanks
Guest
Posts: n/a
Funny, I just installed a Clarion VRX8271 into my 97 2.8qm with Bose. You need to convert the line outs to RCA plugs and then they can plug into the back of your radio, Sean is correct, the diagram is on the radio. I needed two ground loop isolators, as I was getting a pop noise everytime I changed the radio station, however with the isolators, I've had no problems whatsoever..<p>HTH<p>Jason<br>
Guest
Posts: n/a
yellow is RF, white is RR, grey is LF, and green LR, brown is the common... You need to get a set of female RCA and solder them onto the leads... I just clipped the plug off of the radio and used the wires.. Piggy back the brown wire from RCA to RCA.. Right now I'm using the aftermarket head unit with the stock BOSE amp and speakers..<p>Be sure to get the ground loop isolators, or you're going to be hating life..<p>Jason<br>
Jeff
11-02-1999 11:39 AM
