I need your help and advice regarding repair shop damage!!!!!
I took my car to a local repair shop this morning to get my A/C filledup. When they went to fill it up via the high side, the high side nipple broke off - or this is what they said. They said the fitting was already cracked which caused the whole thing to snap off when they were filling it. I believed them until I took a close look and saw the break. It looks clean all the way around. I see no evidence of a pre-existing crack. Take a look at the pics and let me know if the shop is BS'ing me. Also, is this a common problem? Thanks
<img src="http://pictureposter.audiworld.com/84564/100_0613.jpg">
<img src="http://pictureposter.audiworld.com/84564/100_0614.jpg">
<img src="http://pictureposter.audiworld.com/84564/100_0615.jpg">
money to replace and I need to know If i should make them pay for it or if it looks like an honest error?
AudiWorld Uber User
pump refrigerant into a system without testing it first. There might be EPA requirements which they did not follow. If there was an existing crack that was bad enough to snap off, it must have been leaking.
If they knew the system had a leak or crack, they had no business filling it with refridgerant.
Especially because it is the ac system and it must be closed for them to recharge it. It is a major fine to release the chemical into the air so I would expect them to have to leak test the system before putting any additional in. Usually if it looks like something may break a shop will ask you if you want them to try to do the work.
