I ran out of gas, put more gas in, but car won't start...HEEEEEELP!!!
First be sure to add more than just one gallon. Best if you add 3-4 then becuase you may have air in the line you need to just turn over the engine for up to a few min. You shouldn't need to pump it, the fuel pump should do the work. Give it a try..
No gas means it will overheat and fail. Although I only heard of one incident of running out of gas causing an explosion (fumes + heat ~= bomb), that was in the old days where they didn't have sealed gas systems and charcoal canisters.
There is a fuse #28 IIRC. Check to see if you have voltage there while cranking. That is the fuel pump fuse. Also, you can bypass this fuse to 12V. If you do not hear a faint sound of a fuel pump, consider it bye bye. GoodLuck
