I think I found my coolant leak
<center><img src="http://pictureposter.audiworld.com/19986/leak.1.jpg"></center><p>It seems to be in this area here. It's right behind the lower grill. Any ideas to what part may be leaking?
Right behind there. I've had a slow leak for a while and there is no obvious pink crusty crap so I've been a bit frustrated. I suspect it is the drain for the radiatior like f3d is saying but it's not leaking fast enough to annoy me into taking the bumper off.
Mine, in the same area, turned out to be the radiator itself. Unfortunately an increasingly common problem with older cars, the bottom of one of the vertical 'tubes' on the sides of the radiator begins to leak at its union with the radiator coils themselves. However, in your case, the leak is on the side of the radiator drain, so hopefully it's just that.
pretty much right behind it. the hose is a b*tch to get to..did anyone touch that area of the car recently? or did you run over anything large recently?
