Idle speed for A4 2.8Q?
Old 05-23-2000, 07:00 AM
New Member
CMYK's Avatar
Default Idle speed for A4 2.8Q?
My 2.8 is a week old. It idles around 850rpms. Seems a little rough at times.
Old 05-23-2000, 08:03 AM
New Member
TFHADERMANN's Avatar
Default Same here on a 7k A4 2.8...seems to be "normal" per other posts here......
also, mine usually does a slight "shake" after the clutch pedal is depressed when stopping. The idle drops to about 700rpm, then up to about 1,000 rpm, then idles normally at 850. Apparently this is a "characteristic" of the 2.8?
Old 05-23-2000, 08:36 AM
HiTEC's Avatar
Default The ECU will run the engine very rich upon starting.....
If you don't let the engine warm up a bit you risk the chance of fouling your plugs.
Your lucky it is warn outside, it seems to be a bigger problem when the temp is colder.<p>Brad Bilut, A4 98.5 2.8QXTipPES
<a href="http://registry.audiworld.com/audi/registry/details.asp?car=874 "><img SRC="http://pictureposter.audiworld.com/AudiWorldPics/2000/bilut_a4.jpg" BORDER=0></a>
Old 05-23-2000, 05:37 PM
New Member
cap037's Avatar
Default I've got 5.1k miles on my '00 2.8...
When I first start the car in the mornings, the tach hovers at 1100 RPM and seems a bit rough. As the engine warms up, the idle drops down to about 700 RPM. I assume this is normal?
--Cap
Old 05-23-2000, 06:40 PM
New Member
HeavyC's Avatar
Default Re: Idle speed for A4 2.8Q?
My 98.5 2.8Q has the same "characteristics" described in this thread. Starting cold it jumps to 1100 rpm then plops down to 850 after a minute. Typically at idle you can feel the slight vibration, some say due to the v-6 design. Will audi ever venture to the inline motor?
swissdrive
S4 (B8 Platform) Discussion
02-18-2011 11:06 AM
Richard Goulding
10-08-2004 04:35 PM
Avant Sport
04-25-2003 04:37 PM
BiturboBoy_V2.0_S3--
03-29-2001 12:53 PM
chris murphy
05-25-1999 01:29 PM
Quick Reply: Idle speed for A4 2.8Q?
