if the abs module is disconnected, will the brakes still work??
because you can pull the fuse (number 7 if I recall) and that will disable the ABS. Keep in mind though that disabling the ABS will also disable the EDL (electronic differential lock).
S4 Slowpoke
10-10-2006 06:10 PM
bladernr
06-28-2006 05:48 PM
Any FAQs on removing the ABS computer? Will the brakes work (w/ out ABS) if the computer is removed?
RageRacer
03-10-2005 09:02 AM
