if i have a bad wastegate should i replace it or the whole turbo????
just replace the waste gate. A $175 part is better than $800. I think you would look for excessive play in the shaft and see if the fins are bent or broken. Also if there is a lot of oil in the turbo housing itself, those would be indicators that the turbo should be replaced. You also need to see if its the flap itself inside the turbo or just the wastegate acuator. I think if its the flap that broke, you need a new turbo
From whatI've read on the forums, its commom for these k03/k04 wastegates to blow.
Rokšped
14
08-01-2004 08:41 AM
Oettinger_A4
07-10-2004 07:09 PM
