If one can see timing belt, can one inspect to see if it needs to be changed with naked eye?
Old 03-14-2002, 09:37 PM
New Member
Maddog's Avatar
Old 03-14-2002, 09:44 PM
WYSIWYG's Avatar
yep
Old 03-14-2002, 09:47 PM
Member
Silver Streakin''s Avatar
Default yes, but only if it already broke. it's difficult to tell when it will break. just replace it.
<ul><li><a href="https://forums.audiworld.com/a4/msgs/1084042.phtml">https://forums.audiworld.com/a4/msgs/1084042.phtml</a</li></ul>
Old 03-14-2002, 09:59 PM
New Member
wi_97_A4's Avatar
Default ... before it breaks...
Replace it before it breaks, I had to replace my entire engine at 62000 miles... Audi paid for half, but it still cost me $4500...
Old 03-15-2002, 09:26 AM
Donovan's Avatar
ouch!! full cost was $9,000 !!!!!!
Old 03-15-2002, 10:46 AM
New Member
kam1200's Avatar
Default You cant really tell by looking at it visually....but...
Youd have to look at everything and most likely you wouldnt see any sign of warning.
Aside from the outer area of the belt itself., there are also teeth that can break then will cause the belt to slip, bending a few valves just as if the belt had snapped. Your car will shut off. Then when you of course attempt to start your engine again, the pistons will move up, the valves will move down (un-aligned of course)and hit each other and BAM! Vent valves again. Not a good situation to be in, Ive been it it before. Trust me, fix it before its broken.
The belt just snaps without warning. But if you really really reallly wanted to inspect your belt. You could: Grab a magnifing glass and visually check the outer areas of the belt, then both sides, then inspect each indivual tooth, inspect the inner side of the belt, and the portion of the belt that is wrapped around spockets.
Then you'd have to check the sprockets and your water pump and any other other related parts. Then after all that checking you could STILL snap the belt from water pump failure or just plain old bad luck.
Best bet is to replace it as soon as you have some time and extra money before the 80K mark. Sooner the better.
Old 03-15-2002, 01:50 PM
BostonBrian's Avatar
Rubber looks brittle, cracks, etc.
Old 03-15-2002, 02:14 PM
New Member
Maddog's Avatar
Default I checked it and it looks shiny and glossy, I bought it with 105K miles, so it must have been....
replaced, do you think?
Aniforatos
11
05-06-2013 05:39 PM
nynyvtecjstkickdinyo
NY / NJ / CT Discussion
04-21-2008 05:09 PM
vaughn-gotti
08-02-2003 12:12 AM
selfproclaimedv8buff
22
06-27-2002 08:39 PM
Ron
02-18-2000 07:43 AM
Quick Reply: If one can see timing belt, can one inspect to see if it needs to be changed with naked eye?
