Im freakin out!! Name that part please!!!!!
well i didnt get the head back tonight, argh, but i decided i should start preping for when i do get it back. and i noticed this broke...
<img src="http://pictureposter.audiworld.com/78567/dscn0338.jpg">
It may be hard to tell, but i need to get a new hose of the broken one on the right. That hose is directly underneath the intake mani and it bolts on the right side of the crankcase of where the pistons would be.
This is the back of the hose, where it bolts to...
<img src="http://pictureposter.audiworld.com/78567/dscn0340.jpg">
Ill try and be more clear...that hose bolts to the the top right side of where the piston block is, its right below the head which is not in there, duh.
By looking at the bentley in the "vaccum diagram", i think it is telling me it is the crankcase ventilation. I cant find a picture of it online of the diagram in the bentley so its hard to explain here.... If you were looking at the Preesure control valve, follow the hose that wraps behind the engine, and it ends at the crankcase where the pistons are.
So im looking for varification from AW of what that hose is called. crankcase ventilation hose?? Fawk im confused and need a break!!!
baaaahhh i want to get my car running dammit!!!
Keeper of the Cash
058-103-213 breather tube
06A-103-247 bleeder valve housing
035-103-245-A bleeder valve
Those are the parts you will need for that section.
Otherwise, I suggest you follow this article:<ul><li><a href="http://www.scottweese.com/images/pcv/pcv.html">Complete 1.8T PCV System DIY</a></li></ul>
Looks like GilliamOS already has you taken care of, here are a few more...
<img src="http://images7.fotki.com/v134/photos/4/48510/1619277/PC170070-vi.jpg">
<img src="http://images7.fotki.com/v130/photos/4/48510/1619277/PC170071-vi.jpg">
Good luck.
Andy
Good luck.
Andy
Keeper of the Cash
Great info in that post, its really going to to help here in a bit when I do my PCV system
Searching ROCKS!
Searching ROCKS!
