I'm having a problem with my ABS coming on to easily.
If not a studless snow it could be the tires or if studless just be conditions and road surface film . All seasons with a Mud & Snow rating aren't snow tires if you have those.Is there an underlying ice layer ? I have seen a bad wheel bearing affect ABS due to bearing movement interpreted by ABS module as wheel speed difference at low speeds and causing ABS activation when not needed. Could be a number of factors. Are brakes good / free . One could be locking and causing issues . Sensors OK? If rust is on a reluctor ring or you have a cracked reluctor ring it can give a sensor reading that causes ABS activation too. In deeper snow ABS activates easily . We need some more details to help you.
And it is at low speeds that it activates to easily. so but at highway sppeds there is no wheel shake how can i tell if it is a wheel bearing? Are they hard to change on this car?
