im taking apart the maf as we speak, and I cannot for the life of me figure out what kind of screws
#11
<img src="http://pictureposter.audiworld.com/92486/p1010008.jpg">
You can see in this photo where air flows through the sensor, that's the part that really matters.
<img src="http://pictureposter.audiworld.com/92486/p1010007.jpg">
#13
If you're using rubbing alcohol, make sure that everything dries before putting the MAF back in. The stuff you can get at drug stores is usually 20-30% water, so it may take a while to dry.
I used the CRC MAF cleaner and it worked really well. It has a strong, narrow spray that helps get all the guck out.
#15
for it to dry? its been sitting drying now for about 25 min, i see little wet spots but not many, is it ok to re-assemble and then just wait another 15 min or so?
Would you say that is sufficient the alcohol i used is 30% water
Thanks guys
Thanks guys
#17
I'm supposed to go somewhere tonight, I didn't know it would take that long. Is that really whats recommended or what?
Thanks man
Thanks man
#18
Maybe somone else will chime in...i'm sure the Alcohol helps it dry alot faster. The CRC stuff I used evaporated immediatley.
You could always just try it and see what happens, worse thing could happen is you needing a new MAF :P
#20
alcohol would 100% evaporate ... no?
Anyone want to chime in?
Thanks again guys for your help/opinions.
