Info Request: 60,000 Mile Service Items
For those that have had this work done at the dealer, or for those that have a Bentley manual....I'm looking for a list of the items that are replaced at the 60,000 mile service for a '97 1.8T. My Owner's Manual is kind of vague.
I know that this interval calls for the tune-up items so I'm figuring plugs & air filter (actually I have an ABT filter, so I won't need that). As far as plugs go...what's recommended? Bosch? Beru?
I also know the interior dust/pollen filter needs replacing.
I know I'm due for a timing belt & tensioner change also.
My brake fluid was just changed about 5 months ago, so that's good.
Fuel filter?
Serpentine belt (i.e., ribbed V-belt)? According to the Maintenance book that came with my Owner's Manual, this is to be replaced every 90,000 miles. Anyone see a reason to replace it early? I guess it can't hurt.
Coolant change?
Anything else?
So here's what I think my list of items to replace is:
- Spark plugs
- Interior dust/pollen filter
- Fuel filter
- Coolant change [possibly]
- Serpentine belt [possibly]
- Timing belt & tensioner [not part of 60k service, but should be done now or very soon]
Appreciate the help.
Fuel filter?
Coolant change?
Anything else?
- Spark plugs
- Fuel filter
I thought I remember somebody posting that this thing is a PITA. It's somewhere on top of the fuel tanks (which must be removed)...and Audi set the change intervals really high.
My memory could be fuzzy here, and then they may have moved it between model years, so this is just something else to put a ? next to. Sorry, that's all I can help with...going in for 20K this weekend.
Bosch plugs - F7LTCR.
Fuel filter
IMO do all of the belts or at least timing belt
Check motor mounts
Coolant change is not as crucial as the belts but it won't hurt (esp if you have oil in it).
You can do the tranny and the coolant fluid later.
Something else I'm forgetting..
Fuel filter
Check motor mounts
....it may have been CP or Clark that posted about it. I'll have to do some searching. Given what I remember of the post, it did indeed sound like a PITA to replace....may have to leave that to the pros. Thanks for the feedback.
....you think the manual trans fluid needs to be changed? I'll have to consult with my mechanic and get his thoughts. Can't hurt I suppose.
Some of the guys here (Innovator & Clark) are using Royal Purple Maxgear tranny oil (synthetic). I don't think there is a need for that particular oil unless your have unsmooth shifts in the cold or *occasional* grinds. The factory oil is fine matter fact I would request some TT lube, since it is synthetic and all.
If you don't do it at 60, definatly do it at 90k.
Glad to have helped,
....the trans lube that Audi TT's are running? My A4 has always shifted well...no grinds unlike a lot of the newer A4's that seem to have issues with the 1-2 (or is it 2-3) shift grinding.
How cold does it get in your area? Has your tranny ever become difficult to shift?
I'm in Ny and it gets bad at times. I can easily grind into second in the cold if I don't rev match and/or double clutch.
Must be some sort of assembly line screw-up during build.
It's a pita but I'm going to have to 'deal' with the dealer in order to rectify this situation.
BTW: have them check for any exaust leaks
....when the temps were down in the single digits last year, I shifted very slowly as I knew everything was frozen up. But the only grinding I've ever had has been due to me slightly missing a shift....doh!
Kenny
NY / NJ / CT Discussion
04-10-2008 04:04 PM
DeutschDriver
9
09-01-2006 12:32 PM
DaveyKid
RS 6 Discussion (C5)
10
03-05-2005 05:58 AM
Phillip G
11-20-2000 12:08 PM
