Inside cabin water leak. Is the drain hole for the evaporator simply jam MORE
I would like to know if someone had to clean out this drain and mainly where is it located. I have water coming in when using AC only so I am almost sure that this is the problem
Any help out there
Any help out there
Hard to see and get to but it runs through the firewall. Often the drain hose gets pinched and water won't flow, and junk can build up in there. Snip the end of the hose so water can flow easily and you some compressed air to blow it out. You might be able to get to it if you pull the glove box off and pull the carpeting back to find it.
TL12vA4
01-20-2011 07:55 PM
S4J
09-20-2002 10:51 AM
