Install help: I'm trying to replace the lower door moldings. Does it matter... *edit*
...if it's the front door? In my reply below I mentioned that sliding the molding over the clip farthest back on the front door looks like it's going to be pretty difficult. Any tricks or just ram-jam it on?
This is my first attempt at these and I've spent about 10 minutes swearing at the car. I've got the old one off obviously, but the clips are still attached to the door. Do you have to take the clips off and install them in the molding? If so, how the fvck do they come off? I attempted to slide the molding on to the clips with no success. It's very frustrating.
the area where the clips fit has reliefs in it. you start with the molding about an inch towards the rear of it's installed position and put it onto the clips and then slide it forward
Also make sure the molding is straight, maybe use a little lube if necessary.
spkd49
08-31-2010 09:31 AM
iove
Pacific Northwest Discussion
04-09-2006 03:12 PM
yorgo25
03-21-2005 12:08 PM
azndrunk74
01-30-2005 09:43 AM
