Installing Adj A4 front Control Arms
Old 11-19-2013, 12:00 PM
  #11
AudiNut87's Avatar
how much is it lowered ? thanks for this info.
Old 11-19-2013, 06:22 PM
  #12
twentysevenlitres's Avatar
I have no idea really.
It's a factory set up, listed simply as "Audi Sports Suspension".
Judging by other non-lowered B5's around the place, I would say 30mm minimum (1.25").
Old 12-05-2013, 06:48 AM
  #13
AudiNut87's Avatar
what does everyone set their camber at for these ?
the arms are super easy to install.
Old 03-12-2014, 07:31 AM
  #14
AudiNut87's Avatar
up for this question
SPC 81350 Audi B5, B6, B7, C5, and VW B5 Adjustable Front Control Arms!
*** GROUP BUY PRICING IS IN EFFECT --- SET OF 4 --- LIMITED AVAILABILITY ***
As many of you have found out, when lowering your suspension, camber and toe become misaligned which leads to expensive tire wear and poor handling. Since the OEM has made no provisions for lowering the vehicle, there is no adjustment that can be made to bring the wheels back into alignment on a lowered vehicle.
SPC has released this Set of 4 adjustable front upper control arms which will allow +/- 1.5 degrees Camber and/or Caster change for these vehicles. These arms directly replace factory fixed-length arms, allowing easy adjustments after installation. Engineered for both street and track use, forged 6061-T6 aluminum ends with large 18mm threaded adjuster links assure this is the strongest kit available. Maintenance free ball joints and bushings provide factory ride, handling, and NVH performance.
Click here to see the installation video :
These come as a SET OF 4 and fit the following models :
Audi A4/S4/RS4 – 1996-2008 (B5, B6, B7, C5)
Audi A6/RS6 (incl. AllRoad) - 1998-2004
VW Passat - 1998-2005
This product is SPC 81350 and replaces OEM Part Numbers 8E0-407-505C, 8E0-407-505A, 8E0-407-506C, 8E0-407-506A, 8E0-407-509C, 8E0-407-509A, 8E0-407-510A (and possibly others). (8E0407505C, 8E0407505A, 8E0407506C, 8E0407506A, 8E0407509C, 8E0407509A, 8E0407510A)
115k
Q7 MK 1 Discussion
04-24-2018 08:36 AM
Hibiscus Red S4
10-21-2006 01:25 PM
JAFO
07-27-2004 09:13 AM
MasterB
05-05-2003 04:12 PM
GrA8ful S8
04-01-2003 03:36 PM
Quick Reply: Installing Adj A4 front Control Arms
