Intake question?????
Old 06-25-2002, 01:58 PM
  #11
Senior Member
Turning Japanese's Avatar
Forced induction? Maybe he thought you had a 1.8t
  #12
Elder Member
djnelsen's Avatar
Default it's not really overboard........
a standard cone setup is less restrictive....but it also allows more hot air from the engine bay to be sucked into the engine, which is bad. Hot air will negate the benefits of the free-er flowing cone, and can even make performance worse.
The heatshielding I performed gets rid of the hot air problem (or at least makes it "not worse" than the stock airbox).
I actually plan on running a tube from the fog light area to the cone region to provide even more fresh air....THEN maybe it'll be overboard =P
Old 06-25-2002, 02:07 PM
  #13
Member
Keyna's Avatar
And by the way, it sounds great if you're into that kind of thing.
Old 06-25-2002, 02:30 PM
  #14
New Member
mooks22's Avatar
Default Re: And by the way, it sounds great if you're into that kind of thing.
I am, but i want it not custom like from home depot, but like from a factory.. Thats why i cant make up my mind whether to put in a fliter replacemnet or go and get the lltek intake kit???
Old 06-25-2002, 02:36 PM
  #15
Elder Member
Dead's Avatar
The LL-TEK kit by itself can be worse 'n the "Home Depot" set-ups.
Old 06-25-2002, 02:40 PM
  #16
Former Vendor
Anand@4Induktion.com's Avatar
Default heh i saw your setup and went "oooooo time for a trip to home depot"....
i really like the idea, and have already KINDA started on it, with some VERY thin aluminum w/ some old insulation tape to extend the heatshiled to the rad support... hopefully when i get teh Audi i'll bring myself to spend the time to measure out/cut the top/side pieces and maybe even a bottom one, with a cutout for a Cold air pipe from the bumper!
Old 06-25-2002, 03:06 PM
  #17
New Member
mooks22's Avatar
Default Re: The LL-TEK kit by itself can be worse 'n the "Home Depot" set-ups.
So can anyone give me a definitive answer then. I am looking for a reasonable aftermarket intake setup. What company can i buy one from?
Old 06-25-2002, 03:13 PM
  #18
Elder Member
Dead's Avatar
Default You can buy the LL_TEK set-up. It falls short in the heat shield department(they all do) so you'll
<center><img src="http://pictureposter.audiworld.com/8297/heat_shield_engine_side.jpg"></center><p>need to improvise.
Old 06-25-2002, 03:41 PM
  #19
Jretal's Avatar
Hey Dave, what's the purple pipe going up to your cone filter???
Old 06-25-2002, 03:46 PM
  #20
Elder Member
Dead's Avatar
Default Re: Hey Dave, what's the purple pipe going up to your cone filter???
<center><img src="http://pictureposter.audiworld.com/8297/scoop_pipe.jpg"></center><p><IMG SRC="http://pictureposter.audiworld.com/8297/scoop_lift.jpg">
Quick Reply: Intake question?????
