Integration of non-Nokia phone?
I've got a Samsung SCH-3500 call phone. Has anyone integrated this (or any other non-Nokia) phone into the A4? I'm looking to take advantage of the special features like muting the radio on incoming calls, using the built-in microphone, etc. Thanks!
The approach is straightforward... (long)
WHile I am updating my FAQ (look for it within the week), the approach is identical to the nokia.
All true handsfree kits (those say that they require "professional" installation) use the same wiring scheme:
An unswitched 12v supply for charging
A SWITCHED 12v supply for signaling when the car is turned off.
A ground
Speaker output (2 wires)
Mic input (2wires)
You want a kit that supports radio muting, otherwise the Audi radio will not mute, and the speaker output will not get directed to the built-in speakers. In teh case of Bose, its a dedicated speaker, but controlled my the head units, in the case of NON-BOSE, the speaker output from the handsfree is routed through the headunit and user selected to go to the right or left front speaker.
Some kits may have other "features", but those are the basic ones you need.
To interpet the nokia FAQ for another brand, just substitute the correct wire from your non nokia kit.
In the case of the new FAQ, it will eliminate the RJ45 box in the older FAQ, and places the handfree controls under the rear seat, a far more accessable place from the trunk (DB25 connector and antenna), and the console (the cradle).<p>
A ground
Mic input (2wires)
BTW Ed, the reversal of the 8 wires did the trick for the privacy handset-thanks
<p>Eric
99.5 2.8 Jaspis Green QM OMP Strut tower brace, Bilstien/Neuspeed Sport Suspension,K&N, Remus exhaust
Can the install be done with non-factory speakers?
First of all, Thank you for an amazing FAQ! Seeng how professional this DIY Mod can look has convinced me to buy the Nokia hands-free module.
I have a question. I have a 00' Avant 1.8T with Symphony head unit (no Bose) If I replace the factory front door speakers can I still use the hands-free phone? I heard that Bose setup used a two coil speaker removing which will eliminate the phone speaker. Is that true? Is that also the case with non-bose systems?
- boris
- boris
Info.
Changing door speakers won't affect a non-bose system, since the output is run through the head-unit. Output is selectable between right and left front speakers via the radio (look in the users manual for the radio. It explains it pretty thoroughly.)
The Bose system, has a separate speaker (and grill) for the handsfree speaker, that's integrated into the car. Separate from the radio in the regard that the handsfree output is separate from the radio, but the speaker doesn't activate unless the radio is muted via the ground wire (stereo muting).<p>
Northern Ivy
03-14-2003 02:12 PM
plug1
11-12-2000 03:10 PM
Tim
02-04-2000 12:58 PM
