its crazy how many problems the little coolant temp sensor
was causing me. wierd start ups, wierd idles (sometimes in neutral the rpms would climb for no reason), etc. swapped it out and everything seems to be running 100%. i started and shut it down about 6 times or so, then let it run for about 5 minutes.
mixture as it is supposed to when the engine truly is cold. Oft times the sensor occilltes between temperatures 'reported' and the ECU falls into and out of enrichment. IIRC the cold engine sequence either takes the O2 sensor out of play or at the least alters the influence the O2 sensor has on controlling the mixture.
or more 1.8s than 2.8s...I've observed that my engine temp gauge takes 5-10 minutes to level at Normal. It stays at 0 (cold) initially. Seems abnormal to me.
that they report cold. That said, the fact that it takes 5-10 minutes for your gauge to reach normal operating temperature is NOT indicative of a bad sensor. It is normal for it to take a while to heat the engine, engine oil and coolant to operating temperatures.
For the oil gauge, I am used to waiting about 10 minutes (even after driving the car) and I know that is normal. But this is the first cold season that I've noticed such a 'waiting' period with the engine temp gauge. Usually it's up instantenously. So naturally, I assumed there's something broken.
from ~40 degrees F to 210 F?
During the summer months when it is possible to have the coolant at 80 or 90 degrees F it will take substaneously less time to rise to full operating temperature but even then it will be far from instantly.
Jniebles
A4 (B7 Platform) Discussion
11-01-2012 06:28 AM
Biscuit141
Audi 100 / A6 (C4 Platform)
12-22-2004 04:29 AM
