I've searched but I can't find a real answer. Can you disable ABS?
Pull whatever fuse is related to is, then test it out. My guess is that when you pull the fuse the ABS not happy light will come on, which should be your indicator that the ABS has been disabled.
-Phil
-Phil
disconnecting this.
<img src="http://pictureposter.audiworld.com/34747/100_0132.jpg">
But I thought it would probably disable the braking entirely.
I took out fuse #7 like the manual says (is abs) and the car wouldn't start. HOWEVER! I found 2 more fuses in the manual (which I will try today) that are also connected to ABS.
Fuse #7 = Anti-lock brake system (10 amps)
Fuse #16 = ABS + Anti-Slip Regulation (ASR) (5 amps)
Fuse #41 = Anti-lock brake system (25 amps)
I will try these out later today.<ul><li><a href="http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2400649772&ssP ageName=ADME:B:LC:MT:1">Oettinger Rear Spoiler For Sale on Ebay</a></li></ul>
