Just installed Koni coilover. Why is the ride so bouncy?...
I have no gap front and back. The adjustable collars are about 5 turns from the bottom. I know the springs will settle, so I will re-adjust them. Did I set the dampers too soft? I had no idea how to adjust the front. But the back is feels good.
i'll ride with you and check it out. maybe you're just not used to feeling every nook and cranny in the road. ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
fyi, i have ¯ bounce and body roll is almost completely eliminated. so something is definitely up.
email me if you want to hook up.
I used all the stock bump stops. But I just didn't adjust the front from whatever factory setting is. Do you just turn that polished steel rod on the shock? I made an appointment with a shop on Wed. to check things out. Probably take the front off to re-adjust the stiffness. I'll let you know how things go, and see if we still need to meet up. Thanks, man.
the shocks are too soft. it sounds like you are low if there are only a few threads left. you havea bout 70% of shock travel left and you will need to stiffen them up to slow down rebound.
Am I correct in assuming KoniCO's will have "most comfortable" ride quality compared to other setups
RASTA4
03-16-2005 05:29 AM
Sully
12
02-05-2004 11:42 AM
Lenie
01-28-2003 06:50 AM
