Just pulled the following codes. Any and all suggestions needed:
VAG-COM Version: Release 311.2-N
Control Module Part Number: 4D0 907 551 AH
Component and/or Version: 2.8L V6/5V MOTR HS D01
Software Coding: 06201
Work Shop Code: WSC 06335
5 Faults Found:
17549 - Load Calculation Cross Check: Implausible Value
P1141 - 35-10 - - - Intermittent
17547 - Shareware Version. To Decode all DTCs
P1139 - 35-10 - Please Register/Activate - Intermittent
17545 - Shareware Version. To Decode all DTCs
P1137 - 35-10 - Please Register/Activate - Intermittent
17537 - Shareware Version. To Decode all DTCs
P1129 - 35-00 - Please Register/Activate
17535 - Shareware Version. To Decode all DTCs
P1127 - 35-00 - Please Register/Activate
I have a 98.5 2.8qm
5 Faults Found:
I have a 98.5 2.8qm
I failed the following with the car running at idle:
Exhause Gas Recircuulation: Passed
Oxygen Sensor Heating: Passed
Oxygen Sensor(s) Failed or Incomplete
Air Conditioning: Passed
Secondary Air Injection:Failed or Incomplete
Evaporative Emissions: Failed or Incomplete
Catalyst Heating: Passed
Catalytic Converter(s): Failed or Incomplete
*You do need to register your VagCom software.
Code1=
Load Calculation Cross Check Range/Performance
Code2=
Long Term Fuel Trim Add.Fuel,Bank2 System too Rich
Code3=
Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
Code4=
Long Term Fuel Trim mult.,Bank2 System too Rich
Code5=
Long Term Fuel Trim mult.,Bank1 System too Rich
Code1=
Code2=
Code3=
Code4=
Code5=
camikazi2k
12
02-20-2006 05:20 PM
Michael Benno
09-09-2003 10:27 AM
