Just wondering if mixing G12 plus with water has any effect on the temperature the car runs at?
Recently I've had a timing belt job done on 1.8T AWM. I've noticed right after that the oil temperature is at 230F after warmup, just 1 bar off the middle of the gauge. Before it used to sit 2 bars off the middle at 210F after warming up and would move slightly to the right when driven hard. The coolant temperature sits dead at the middle after warmup and does not move further. I didn't ask the mechanic who did the belt job whether they mixed the G12 plus with water when replacing the coolant or not. I know that the oil is cooled with the coolant, so the question is whether mixing G12 with water matters on how hot it gets. Less water = hotter?
AudiWorld Expert
This is for Dexcool, which is G12 equivalent...
The mixing should not affect your oil temps much though. Is it possible there is air in the system?<ul><li><a href="http://www.valvoline.com/products/zerexdexcool.pdf">http://www.valvoline.com/products/zerexdexcool.pdf</a</li></ul>
AudiWorld Expert
if you're doing a complete flush.
<a href="http://www.geocities.com/dtmcbride/home_garden/auto/antifreeze.html">Link 1</a><ul><li><a href="https://forums.audiworld.com/tt/msgs/823239.phtml">Link 2</a></li></ul>
MYTTS
07-17-2006 05:44 PM
A4_Mation (Dave@ETA)
03-16-2004 06:46 AM
Famous Mortimer
10-20-2002 03:40 PM
Killer Bee
06-08-2001 06:27 AM
a3, audi, awm, coolant, discussion, equivalent, equivilqnt, explained, g12, mix, mixer, mixing, plus, top, water
