K04 Turbo owners I have a question
Guest
Posts: n/a
After seeing my K03 Turbo glow for the first time it convinced me to upgrade to a K04. But i hear that the K04 is slightly bigger than the K03. if this is true does that turbo glow like the K03?<p>Thanks for any info.<p>I will be joining the K04 club soon.<p>
Guest
Posts: n/a
The K04 and the K03 share the same housing, that's why it's virtually impossible to tell them apart once installed in a car. I checked my K04 to see if it glows after real aggressive driving, and it does. <p>Ali<br>98.5 1.8TMS
Guest
Posts: n/a
With that kind of heat, you'll kill the turbo. The oil will coke and the bearing will die early. Install a turbo timer ($100) to circulate oil after shutting off the ignition key. Oh yeah, with a turbo car, always thoroughly warm it up before you "boost" the engine.
Guest
Posts: n/a
What about the turbo itself?<p>You start up your cold engine. Hot exhaust strikes the turbo and it starts to run. What I'm saying is that it would seem that the turbo is one of the first parts to reach normal operating temperature. The coolant takes a lot longer to warm up.<p>Marko Litmanen<br>A3 1.8T Wett 1.0 bar K&N
Guest
Posts: n/a
First off, you have a wastegate that controls exhaust flow over the turbo. At idle and light throttle the turbo probably isn't spinning, or if it is than it is spinning very slow. The reason you want to warm the car up is to heat the oil. You want nice thin [warm] oil for the turbo bearing (and engine) before you start "boosting" the engine. With 1 bar (about 15psi) I hope you're using a good synthetic. Just take it easy and wait until the engine is warm before beating on it. <p>>What about the turbo itself?<p>>You start up your cold engine. Hot exhaust >strikes the turbo and it starts to run. What I'm >saying is that it would seem that the turbo is >one of the first parts to reach normal operating >temperature. The coolant takes a lot longer to >warm up.<p>
Guest
Posts: n/a
Idling for 4 minutes is overkill. Get in your car, start it, put on your seatbelt and than drive away. There is no need to let the car idle after startup. The idea is to get it up to temperature ASAP, driving does this best. Just use very light throttle and don't go over about 35mph until the car is thoroughly warmed up (5-10 min.) You don't really need a turbo timer unless your turbo is really hot upon shutdown (ie., driving hard or running more boost.) If the turbo is glowing red than when you shut it down than the oil will coke on the bearing. 1-2 minutes of cooldown would probably suffice (even after spirited driving) a turbo timer allows you to leave the car while the turbo bearing cools. Prolonged idling is probably the worst thing you can do to your car (diluting the oil.)
djillusion
04-15-2005 08:40 AM
DLX64
Canadian Discussion
03-02-2004 06:14 PM
OneEighth
03-28-2002 03:39 PM
