K04 upgrade
I was told by AWE tuning and PES that it would also be better for you to upgrade exhaust. They recommend a cat-back to ensure the free flowing exhaust emissions due to increased combustion.<p>www.MBnz.org
The Mercedes Owner's Resource
PES uses larger injector in their kit and AWE uses a 5 bar fuel pressure regulator.
The objective of both is to get mor fuel under boost. You don't want to go lean!
You need the proper air/fue; ratios and spark advance map for all to work properly.
NOT a sinple bolt in K04 & go.........do your homework..........search the archives
READ READ READ before you WRENCH WRENCH WRENCH
Jeff Davison
Jeff Davison
rk1.8t
01-21-2004 10:12 AM
Toronto B6 -OnEighty
11-18-2001 01:57 PM
