Key-fob Separating
#11
If you try this let me know if it works. Mine is starting to fall apart, that little tab part seems to be wearing. I would appreciate if you let me know because I could probably see myself buying one in the next few months!
#12
Audiworld Senior Member
I decided to attempt to repair the ones that I have. I have a hard time throwing away a perfectly functional device... Especially when I have two of them that are suffering from same separation problem, and I only intend to keep the car another year or so.
My fix: I wrapped a small piece of gaffers tape around the part of the transmitter-half of the fob that inserts into the key-half. This creates a firm friction fit that securely keeps the two halves together but still allows them to be separated for maintenance purposes. While not exactly "German Engineering", the fix works great, and doesn't change the outward appearance of the fob.
--Phil
--Phil
Rocket3004
05-12-2005 05:35 PM
