KO4 with FMIC? Opinions?...more inside...
Is there too much pressure drop with a KO4 to use a FMIC? The reason I ask is the limitation of turbo options considering my tippy(gotta keep it a family car). Any feedback, positive or negative, would be greatly appreciated.
Thanks in Advance,
99.5 1.8t Tip
GIAC
K&N
Borla
Baileys
Thanks in Advance,
99.5 1.8t Tip
GIAC
K&N
Borla
Baileys
call DSR or ask around here, a few of the KO4 guys run the setup...it used to be called the K30 chip, IIRC, but there is an update.
Cheers,
Sameer
Cheers,
Sameer
the K04 is not going to have a pressure drop over a k03, but it will have a cooler air charge at the same boost level and will also pull in more air flow at that set boost. But even using a FMIC on a K03 helps.
thewatcher101
05-28-2007 05:50 PM
GNC_Man
18
12-14-2004 08:48 PM
Mikey L
05-19-2003 06:12 AM
growlinaudi
12-23-2002 12:19 PM
T-28-Quattro de VT
02-05-2002 09:08 PM
