leak from valve cover gasket in rear where the half circle gasket is...
i can see the oil seaping out under the gasket. Is this common with 0w40? Should i use a heavier oil? I checked and double checked the gasket when i put the valve cover on. I know its on right. its just like the valve cover isn't putting enough pressure on the gasket.
Keeper of the Cash
I would think it should never leak regardless of the weight of the oil you are using.
places that it said. It says to use rtv on the corners where the cam tensioner meets the head and on the corners where the from cam bearing seal meets the head
Keeper of the Cash
on the valve cover (i.e. dirt or the like) and that the cover is properly seated.
old gasket in the half circle. It should be the exact same one. I put the old gasket on, and no leaks.
thxguy
10-25-2009 07:05 AM
AudiTTboi
09-01-2007 09:28 AM
MYTTS
07-24-2006 06:06 PM
