Lemmiwinks CH10: Primary Fuel Tweak. what does it do?
Ch02 : Fuel Tweak (Accel Pump); Increasing Loads
-This channel adjusts a fuel enrichment under load
-Modulates Throttle Response
Ch03 : Fuel Tweak (Accel Pump); Decreasing Loads
-This channel adjusts a fuel enrichment term coming off the gas or decelerating.
Ch10 : Primary Fuel Tweak
Controls fueling on run, ussually change multiplicative fuel trims
- Higher number enrich the mix
- Lower number lean out the mix
most people use Ch2/Ch3 to get their long term fuel trims back to 0. but no one mentions or uses CH10. any ideas the difference between CH10 and 2/3?
<a href="http://forums.fourtitude.com/zerothread?id=1618056">http://forums.fourtitude.com/zerothread?id=1618056</a>
Primary Fuel Adjustment - This variable alters the injector opening times to allow the injectors to open the necessary amount to meet fuel demands. Tweaking this variable up and down can alter the actual air/fuel ratio of the vehicle.
exerpt from APR's v-tune software. which in essence is the exact same thing as lemmiwinks.
HOPSBurner
Chicago Discussion
07-15-2005 01:53 PM
acidrane-teh jeweler
06-09-2004 09:02 PM
Cipher5170
06-28-2003 12:53 PM
