Little help with code 16884/16885
Ok so today, after an important job interview, I went to drive home and kill myself for some of the dumb things I said and my car wanted to kill me too. As soon as I started it, the engine starting shaking and misfiring so bad that I thought it was running on 3 cylinders. The check engine was flashing. So long story short I have it towed home and notice the vacuum that runs from the front of the manifold to the Bypass valve is broken. So I replace that with the correct size rubber hose (5/32" the same I used for my boost gauge) and that doesn't solve the problem. I hooked up the VAG and I got codes 16884 and 16885. I only have the shareware version so I don't know what 16885 is but 16884 reads "Random/multiple cylinder misfire".
Anyone have any ideas what to check next.
Actually I lie... I did read on...
Check out <a href="https://forums.audiworld.com/vag/msgs/2100.phtml">this</a> thread, (and the VAG-COM forum)<ul><li><a href="http://www.bentleypublishers.com/tech/audi/audi.dtc.table.htm?stickyEmail=&ticket=none">H ere is a listing of DTC codes</a></li></ul>
K2audi
Audi allroad
9
01-29-2009 01:11 PM
s4boosted
04-24-2008 12:43 PM
uber_ar
Audi allroad
03-22-2008 06:46 PM
PassatInTheWrks
30v V6 Discussion
01-08-2007 11:09 PM
