Loaded Passat or basic A4 1.8T
#13
Guest
Posts: n/a
And I might not have stretched my budget to the A4 except for the great (under invoice) deal I got on my A4. The Passat (fully loaded, V6) ended up being more expensive than the A4 that I purchased. In the end, the main differences between the two are:<br>1) rear seat room<br>2) warranty (longer on the A4, but 10-yr on the Passat's powertrain)<br>3) lower aspect tires on the A4 and sportier suspension<br>4) obviously, exterior is different (your preference, mine is for the A4)<br>5) the "prestige" factor<p>Like most questions of "which is better?", the real answer is simply to test drive both until you decide.<p>Francis<br>Cactus Green 1.8TQTipS<br>
#18
Guest
Posts: n/a
Order code#3B25S6 -- if I can read the photocopied dealer price list effective May 15, 1998.<p>There is only one Passat that gets Syncro - it is fully loaded with everything - The only additional option is metallic paint - oh ya and the wagon at the rear.<p>I didn't like this choice because of the higher cost and the fact that it only comes with Tip. - I went with the A4...
