Long time suspension knock sound finally ID'd and fixed. Thanx RKA!
Old 09-22-2003, 08:36 AM
shwndh's Avatar
Default Long time suspension knock sound finally ID'd and fixed. Thanx RKA!
<center><img src="http://pictureposter.audiworld.com/44415/shock_mount.jpg"></center><p>There were many posts about a light "hollow wood" knocking sound or clunking sound comming from the front suspension that no one could figure out what it was. Seems it only happeded at low speeds over slightly uneven/lumpy surfaces. But you didn't hear at thing at hwy speeds. Out of all my posts and responses, I got a post response from RKA on 2003-07-21 that sound like it made the most sense and I went for it.
He said to make sure the the nut in the center of the shock bushing wasn't loose. Turns out that was it, and it was very loose. When I pulled the shock out of the housing, you could see thin metal shavings from the plate rubbing up against the threads on top of the shock. It got that way from not compressing the spring enough before I torqed down the nut in the middle of the shock bushing. And you have to keep the spindle in the middle from moving with a hex key to keep it from spinning while you torqe the nut around it (PIA!). I was able to do it with a 18mm socket over the nut, a hex key going through the socket to the bolt, and a pair of vise grips (crude but effective). After I recompressed the spring, torqed it down again, and reinstalled it - No more clunking! (Thanx RKA!)
So if you've tried everything and haven't looked at this yet, it may be your answer. Here's a pic of the shock mount with the nut in the middle above.
Old 09-22-2003, 08:40 AM
Junior Member
JonnyD1.8t's Avatar
I think that is my problem, among others, wow cool thanks for the repost
Old 09-22-2003, 08:47 AM
RKA
AudiWorld Uber User
RKA's Avatar
Default You're welcome...nice work!
Feels good when you can fix something for $0 doesn't it! :-)
Old 09-22-2003, 08:48 AM
shwndh's Avatar
It sure does!
Old 09-22-2003, 08:49 AM
New Member
jfxd's Avatar
Default Saw some guy in CT with the plate 'RKA' yesterday..
was driving a Buick. It made me think of this forum, and gave me the warm and fuzzies.
Old 09-22-2003, 08:50 AM
Elder Member
The Turtle's Avatar
i have that issue as well, but i'm replacing the suspension soon, so i'll do it then
Old 09-22-2003, 08:53 AM
RKA
AudiWorld Uber User
RKA's Avatar
Default :-/ Sign of things to come for me? (buick)
Heh...I just made an offer on a beige on beige 98 accord...more or less the japanese equivalent of a buick!
Old 09-22-2003, 09:08 AM
Member
audiski's Avatar
Default Doesn't surprise me. RKA's a total car nerd.
Old 09-22-2003, 09:11 AM
New Member
jfxd's Avatar
Quite a step down from an S4 I'd say
Old 09-22-2003, 09:12 AM
fussball.biturbo's Avatar
Default sounds exactly like what I have... I just wish I had access to the tools to do that
being stuck in Maine at college isn't always the best
Quick Reply: Long time suspension knock sound finally ID'd and fixed. Thanx RKA!
