Was looking at the total quartz energy 9000 @ purems
Old 07-20-2008, 12:12 PM
  #11
Member
mattarios2's Avatar
So i should run a 0w-30 in summer/spring and then a 5w-40 in winter/fall?
Old 07-20-2008, 02:15 PM
  #12
Audi Junkie's Avatar
Default Yes, I switch visc for seasons. More like 0w-30 for winter/spring, 5w-40 summer/fall.
Cold flow and cold cranking abilities diminish while an oil is in-service, so you always want to have fresh oil in for winter cold. It's another reason I change on a time schedule than actual miles. I go 4x a year, but 3x works too. 2 is fine depending on the miles and # of short trips. Just get in sync with a change after Thanksgiving but before Christmas.
I honestly don't think you need a 5w-40 at all, unless you see oil temps over +210C. Like I said, stick with GC unless you are bored or see a specific need to change viscs.
Old 07-20-2008, 05:54 PM
  #13
Member
mattarios2's Avatar
Default Ok, well if GC can handle both winter and summer then I will continue to run it...
usually my car stays around 215 or so MAX when it's 95-100 degrees out. So it's safe to continue running GC i take it.
Old 07-20-2008, 08:40 PM
  #14
Default +212f is the test temp of the visc to give it's labeled "weight". Your +225 is borderline...
that yes, the oil is thinning but it is not frying and leaving deposits. That is a hallmark of GC, it's exotic methylcrylate PAO base oil. Guys at Bob's chipped in about a $1000 for lab time and our experts did a series of fractilization and wierd molecular resonance tests to find out what the heck it was made of, and it is unique. I doubt a few hours of heated operation would lead to any excess wear. Bottom line too is try a UOA. Since GC was factory-fill, I assume absolute compliance is all regards. The Porsche Approval is no joke in a 30 weight and hard to obtain in over-the counter 40 oils.
Thlampman
Q7 MK 1 Discussion
10-27-2016 03:13 AM
Foogie
S4 (B8 Platform) Discussion
03-14-2012 06:49 PM
TRed 2.7T
07-19-2005 07:25 PM
Kwondo777
Pacific Northwest Discussion
10
04-02-2004 08:29 AM
rakk
01-29-2004 06:32 AM
Quick Reply: Was looking at the total quartz energy 9000 @ purems
