looks like the n75 is bad... only boosting 5psi... which n75 to go with...
ive searched and im definitely a noob... i understand how the valve works... but i dont understand the letters and what they correspond to... thanks again guys
Running pressure directly to the WG would cause it to run 5psi. Might be why he thinks the N75 is bad since it is allowing all the pressure to flow thru it.
But you are right that it might be limp if he isn't running a chip.
