Looks like PC16 software really is aggressive. Since I ended up with 91 octane in the tank
AudiWorld Uber User
from a Shell attendant screw-up, I figured I'd log correction factors to see if it makes a big difference. This is in 46 degree temps.
Block 003---------Block 020
RPM--MAF--Thr--BTDC-Timing Retard
2880 66.59 86.8 13.5 0 0 1.5 0
4760 172.08 86.8 17.3 0 0 0.7 0
6600 186.59 86.8 17.3 4.5 2.2 4.5 2.2
6080 188.61 86.8 14.3 3.7 0.7 3.7 0.7
6320 26.32 17.8 37.5 2.2 0 2.2 0
4640 136.87 86.8 18 0 0 0 0
4840 170.97 86.8 15 0 0 0 0
5440 184.23 86.8 14.3 0 2.2 4.5 4.5
5960 187.15 86.8 14.3 0 1.5 3.7 3.7
6040 46.32 17.4 30.8 0 0 1.5 2.2
The worst I've seen with 93 octane looks like that last line in much warmer temps. So no Englishtown until this gas is completely used up (13 gallons left!!!). It's a mix of 5.3 gallons Shell 87 and about 9 gallons V-Power. That's roughly 90.8 octane. Also, I've never had my throttle angle so wide open before. Good to see that.
5bar fueling 34deg F:
<img src="http://www.modifieda4.com/images/ecu-logs/ATW_K05_stockinjectors_5barfpr.sized.png">
3bar tt180 injectors 25deg F:
<img src="http://www.modifieda4.com/images/ecu-logs/ATW_K05_TT180injectors_3barfpr.sized.png">
I dont have a log of 3.5bar which i am running now.
but...the CFs did go down slightly with the new fueling.
once i finish my SAIP relocation my car will stop running pig rich for so long on startup, CEL will go away and I'll do some more logs (after plugs/oil/seafoam).
then i'll be able to see any change from the move to 3->3.5 bar.
conversely, the fact that you are running near zero CFs means that your setup is capable of more power but the software is holding it back.
i probably wouldn't do that now that the weather has changed...unless you make sure to change it back in the spring ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
do you have a MBC in parallel? maybe you could get more power by cutting off a boost spike if there is one? (i know you dont have a map sensor)
I guess logging N75 duty cycle might show what the ECU is doing.
AudiWorld Uber User
no MBC. I think I'm going to just leave it alone. It runs great and doesn't consume too much fuel, so I'm happy with it.
DrGP
25
05-11-2004 01:55 PM
I am Arjun
17
05-04-2003 05:07 PM
