low boost problem..holds vacuum though..help
GIAC chipped with VDO gauge
used to boost to 15 psi, now only to 5 psi
reset ECU and did TBA..no change..that should take it out of 'limp mode' if that was the problem, correct?
no CEL on
If gauge reads 'normal' vacuum of 22-27 " Hg, does that indicate that there shouldn't be a boost leak in hoses,etc?and more that it is a turbo malfunction? like N75 or wastegate type issue?
any previous experiences would be great
TIA
no CEL on
TIA
archimense
9
05-29-2006 10:40 PM
phoneyman
12-24-2005 10:50 PM
