low fluctuating idle after timing belt install.....what do you think
You are prob. a tooth off. Put your crank at tdc then check the cam marks. Do you have a boost gauge? Are you seeing low vac also? It will "loap" at idle but then run fine at higher rpm. If this is the case then your prob half - 1 tooth off.
Nick
Nick
Interesting. My car (1998.5 1.8TQ tip) started having low idle problems and stalling issues shortly after the timing belt was replaced (80K miles), but I never made the connection.
Mainly my car idles at about 200 rpm lower than it used to. It also drops severely when coming from full speed to a stop and occasionally stalls at this point or just when sitting at a light.
It still does this and I haven't been able to figure out why. The last time I had it in the shop we ran the codes which gave no clues and re-adapted the Throttle Body, which also didn't work.
The timing belt being off a notch seems like a really logical answer though. I'll have to check that out on my car.
Other possibilities I've found in my research here:
1) Mass Air Flow sensor
2) Dirty Air Filter
3) Fuel Pump Relay
I haven't gone through all these on my car yet, but hope to shortly.
Let me know if you find any answers. Anybody else's input would be great also.
2) Dirty Air Filter
3) Fuel Pump Relay
thats what i was afraid somone would say...its a 12v 2.8
i can live with it but I don't like it...is there an easy fix or do i just leave it
jikons
9
04-26-2020 03:42 PM
Cboogie
31
09-14-2017 06:58 AM
bnl107
14
06-22-2005 07:27 AM
dvxpert
12-16-2003 12:39 PM
