Lower control arm joints stuck
I'm doing my control arms. The lower control arms on the passenger side popped out with some hard hammering. I've been banging on the driver side ones since yesterday and they're not budging. I also have a fork shaped ball joint separator that I've been prying with. I've soaked the joints with PB blast many times. They're still not moving. Any clever ideas?
one side came out really easy and the other was a pita. Just keep letting the pb soak in then hammer away or try using the separator. I just about gave up then I barely tapped the arm and it droped out. :-)
<center><img src="http://samstagsales.com/images/vw_matra_3287a.jpg"></center><p>You might consider attempting the removal with the factory tool. Pickle forks and aluminum suspension components don't mix well(read: stress fractures or cracks).
Sorry, I'm not closer or I'd loan you mine. Local no, but these could probably FedEx it quite fast. Napa or Autozone might have a similar version to rent.<ul><li><a href="http://samstagsales.com">http://samstagsales.com</a</li></ul>
