Lower suspension gives the stock wheels that "sunk in" look. Can I use spacers and longer bolts?
Can I use a spacer and longer bolts to align the wheels with the fenders? No, I'm not interested in the "wheels wider then car" look, I just want the wheels to look flush with the body.
Yeah, I know I can buy a set of wheels with a larger offset, but are there any side effects of using a spacer set with factor wheels to achieve this effect?
Also, where can I find such kit?
Thanks,
Tomasz
Thanks,
Tomasz
Hoppen Motorsport has them (see link). $270 for 4 spacers and longer lugs.
<img src="http://pictureposter.audiworld.com/25/s4_122501d.jpg">
<img src="http://pictureposter.audiworld.com/25/s4_122501f.jpg"><ul><li><a href="http://www.hoppenmotorsport.com/spacers.htm">MTM Spacers</a></li></ul>
It's the same as switching to aftermarket wheels that have more offset. Widening the track will make the car corner a bit better, but you are also changing the suspension geometry away from how it was optimally engineered. It's not really that noticeable either way though.
