Lug Bolt Help
ok so im changing the front brake pads and on the front drivers side and one of the lug bolts is stripped out... i mean it is completely rounded i have tried so many different things to try and get it off like hammering on a smaller bolt and using the reverse bolt kit and heating it up nothing. so i need help coming up with a way to to get the bolt off any ideas will help thank you
You have a bolt extractor? Or you can a drill bit slightly larger than the threaded area on the bolt and drill straight through the head of the bolt. When it tapers down you should be able to rip the larger head off. You do risk damage to the wheel. Im surprised the reverse thread extractor didnt work. Are you using a large breaker bar?
4000fixes
02-01-2009 06:09 AM
btruby
07-18-2007 05:55 PM
17th Letter
04-04-2006 05:15 PM
