MAF swap for AEB...
#12
If it is MAF restricted, swapping another MAF that reads higher sounds like the thing to do. If its ECU restricted, we're SOL.
BUT--
If the PC-16 file isn't written to take advantage of higher MAF readings, having a MAF that reads that high won't do you any good.
My problem with the file is its a very poor daily driver. It makes a ton of power at WOT, but everything in between seems mushy. I think when the MAF is maxed out, it assumes WOT and full boost, and makes the right amount of power.
BUT--
#19
in any scenario, scaled or not.
In that case there is still fueling via RPM as an example.
Take my car for instance, when I see my 187g/s limit, the software pretty much dumps fuel at a given rpm to prevent a lean condition.
#20
the fact that its maxed out at 187g/s which is what the stock programming maxes out at, means that:
-he doesnt have the pc-16 file
or
-the pc-16 does no maf scaling
or
