Man!! Engine stalls after start...IAC error code...help!
my 99.5 1.8t engine just dies after it's started. i took it in to a mechanic and they read a faulty IAC code. others have had this problem and they fixed it by cleaning it out, but some other have said that if it creates a error code then it needs to be replaced. do i need to replace this or just clean it? thanks.
Sounds like you've got a massive vacuum leak, dead MAF, or a faulty throttle body?
Of course, it's difficult to diagnose over the web....
there's no idle valve on a 1.8t.idle is controlled by the ecm.how does the car run?does it stall on decel?if so,the throttle blade may be dirty.if the blade is really gunked up,it can set maf faults.
Still getting the 17549 - Load Calculation Cross Check: Implausible Value P1141 - 35-10 - - - Interm
Kris Hansen
06-24-2008 05:41 PM
BTCC A4
04-04-2004 07:41 AM
JohnP520
04-11-2003 06:50 PM
bretto
03-13-2003 05:23 AM
