Mark P or others... how can I wire in my boost gauge to come on when the lights are on?
AudiWorld Expert
I looked in my manual to find the fuse that goes to the parking lights...
I then probed that fuse to verify it did indeed have power only when the lights were on. Then I removed the fuse and probed again. The side of the fuse that no longer has power is the "protected (fused) side". It is to this side you want to connect to. Then I removed the back of the fuse box (remove knee bolster first, duh). I located the wire that went to that connection that I needed - I reprobed again to verify and then I spliced in to that wire.
If you have a separate fuse for your boost gauge, you can tap to the unprotected side of that fuse, so that you don't add any current to the fuse that's already there - however I've had no issues with the small addition of current that the boost gauge light (EL in my case) draws.
Lemme know if you need more info - sorry, the only pics I have are on my site and I don't think they show this connection. Click on my sig pic to get to my site
make sure you wire it to include the fuse in the loop instead of before it.
i forget which way the current is going. pull the fuse, touch a voltmeter to both the one that is still ground is after the fuse. connect to that one.
BlackMagicTT_S4
05-26-2005 03:32 AM
selfproclaimedv8buff
02-17-2005 04:06 PM
silverA4TQM
12-09-2004 07:21 AM
Stratocaster1422
07-07-2003 09:31 AM
mau
06-20-2002 11:22 AM
