maximum bore for an ATW block? archives say 83.5mm is safe (more)
#11
and you'll have 2L. There is very minimal extra machine work to make it fit as well. Pistons will cost the same, and you use the same rods.
#12
also arent the rods a weakpoint for our engines when you get up into high boost/HP?
#13
you need 83mm custom pistons ( but some other specs on them have to be changed as well )
you'll still want rods (same ones you'd use in 1.9L)
you'll need to get a little extra machine work done..the walls of the block will have to be clearenced for the aba crank/rods, and the IM shaft has to be machined.
it's not really much extra work.
#15
They are exactly the same as the custom set they made for my car back in 2002. I would show you guys of the new set of JE pistons I had put in because the ring landings were bad on my old set, but I cant so you guys will have to wait till after the DM magazine issues comes out. :P
But believe me there is plenty of block between the 2 cylinder walls with the 83.5mm bore, even to put up with the 32+psi boost levels I run.
