MBC install
<center><img src="http://pictureposter.audiworld.com/85318/mb_vs_n75.jpg"></center><p>is this the way you should connect your MBC the way I see, it makes no sense this way or I am wrong,
any info???
any info???
Otherwise referred to as installed in "parallel".
The "other" way would be to leave your N75 connected electrically, and run the boost lines through the boost controller. This way, you'll need to have the boost level set real close to what the ECU is requesting, and this will change dependant on the ambient air temperature, which makes it real hard to keep effective.
Another problem with that is, everyone will have the devil on one shoulder saying "crank it up, dude!". ;-P
But like Mat said below, I only did it to control the initial boost spikes I was seeing.
MiliTTary
07-30-2007 07:17 AM
ski ya later
05-12-2006 12:08 PM
2001s4loored
12
04-19-2006 02:38 PM
nizmosx
11-10-2004 02:30 PM
