Mechanic needs some advice...
#21
What type of clutch are you putting in?
Both South Bend and Clutch Masters can resurface the flywheels at a cost, but also offer it at a discount when buying one of their clutch kits.
Going with a new single mass flywheel is not as issue on the quattro cars, just make sure to stick with one that is not too much ligher then the stock flywheel. So something around 19-20 lbs will give you zero gear rattle even with the AC on.
Austin Veedub has that single mass kit for $550.00 which is what I told the owner to go with. He ended up piecing together stuff for a little cheaper. The consensus now is he is going to sell the car after this is a done deal. I dont blame him. Im not saying Audi is a bad car, just that someone on a budget shouldnt own one. For instance... New Flywheel $900.00 Audi. Ford is $91.00 FROM FORD!! You get what you pay for? Im not going there. I have done numerous passes down the strip in my cars, running 12.2@111 then driving home with no issues. Thats all im saying. I mean, bottom line, they are all junk and they ALL break.
Sachs? Anyone have any experience with this? I told the owner not to buy online as the CV axles were wrong. So could be the other stuff. Not only that, but at least the local companies can "vouch" for the product they are selling you.
#23
Lets take a look... The clutch, PP and TOB are made by "Sachs" - which is someone I have never used. All my Mustangs get FRPP or a well known aftermarket part that you would find in Summit or Jegs.
There are aftermarket (Luk) dual mass out there for under $400 if you look. Price is coming down, virtually all diesel cars use dual mass nowadays and diesels outsell gas cars worldwide.
#24
Sachs is OEM I believe been around for 50 years or so in Europe. Dual mass flywheels are expensive for all cars not just Audis.
#25
You cant compare an Ford with a German made car when it comes to parts. When you say you buy clutch kits from sold by Summit and Jegs. Its the same thing as A4 owners saying they buy South Bend or Clutch Masters, both are USA based companies. CM is located right here in Socal and I go to their shop often.
OEM A4 flywheels might be $900 but aftermarket single mass flywheels are half that price.
#26
Car was holding up just fine till 2009 when I started pushing the power to 650whp, thats when I broke 3rd gear in 2 stock 01A 5 speed transmissions. Have one in the car now that has been treated and taller 1st/2nd gear and running a flow control valve, just haven't been able to test it out yet.
#27
The flywheel being spring loaded is not turnable. If the bit grabs a high spot its going to tear into it and no doubt chatter. Locking it is not possible with most machines I looked at as the machining bits arm wont clear. There is also a plastic piece that is on there that seems very brittle and the dealer wont say if they have another one. They just want to sell me a whole flywheel for $850.00 + tax.
South Bend even has a Tech page for inspecting the Dual Mass flywheel before sending it in to be resurfaced.
http://www.dxdracingclutches.com/inspectdmf.html
#28
10's are ok, I am aiming for 9's now once I get my new EFR setup.
#29
I shouldn't have a problem with the motor. The weak link on the A4 is the transmission, the 01E (2.7t) transmission is much stronger but it isn't geared right for a 4 cylinder and I dont have $5k-$10k to spend on a custom 01E transmission.
There is a B5 A4 in Europe that runs 9's and making about 850whp. It runs a 01E transmission.
#30
Anyway... just so you guys know - the Audi parts came in and the car is DONE. Finally! runs perfect and the owner is pleased with it. Thanks for all the help... Much appreciated!
Good luck running 9's! Maybe this year I can actually make a race...
lexsmith
12-05-2013 07:20 AM
Horch it
03-10-2009 07:50 AM
TTanman
12
03-22-2007 02:08 AM
