Mechanical problem, what is my next step?(long)
Guest
Posts: n/a
I was going to write in detail everything that has happened and what I have done, but it was way to long. Here is the short version:<p>There is a knocking noise in the front passenger side of the car that you can hear when I drive over SOME bumps, not all bumps just some of them. I have taken the car in 3 times to the dealer to have it fixed, but they have been unsuccessful, because they do not know what is causing it.<p>In the 3 times I have taken it in, I have driven with the "Quality Control" guy once, and the Southeast Audi Representative another time, both heard the noise. But when I take it to service, the service tech cannot find anything.<p>I just got it back after the third time, and the service write up states: "...car is performing as designed". Which tells me there is nothing more they can do. <p>Any advice on my next step would be helpful. Should I take it to an independant service shop? If so, does anyone know a really good one int the Atlanta area?<p>Thanks in advanced.<br>MKM
Guest
Posts: n/a
The number should be in you rmanual. Give them the name of the dealer, and the names of the people you delt with. I can't believe that they would admit to hearing the problem and then say that there is nothing wrong.<p>I would also try going to another dealer in your area. If they can solve your problem I would write your former dealer a nice long letter explaining that you will never be using them again, and once again give the names of the individuals involved.<p>Just some generic consumer advice. Hope it helps!<p>Stu Koch<br>99 2.8 qts
Guest
Posts: n/a
I beleive it is toward the front passenger side(I wish I knew the exact location, it would probably help). It is not a rattle, it is more of a knocking.<br>I am really not sure if I am feeling it more than I am hearing it.<br>I had a freind of mine ride with me and he said he could feel it in the floor board...<p>MKM<p>
Guest
Posts: n/a
This to me should be locatale by a god mechanic, but maybe I'm wrong. Some ideas:<p>1) Loose/bad shock absorber mount. This should be locatable by opening hood, then REALLY push HARD up and down on right front suspension. if the bushing is bad, should get a knocking. I think there is a plastic cover over the shock mount under the hood; if you take this off and place a hand on the shock, if you're getting metal-on-metal contact, should feel it.<p>2) Loose shield under the car. I had a Coupe Quattro that had a exhaust heat shield that loosened up and caused a rattling on initial startup. You might have a similar item or else a loose pipe hanger. This should be able to be determined by grabbing the pipe (when car is COLD) and shaking hard. if something is loose, or you ahave an interference problem, this should show up.<p>Knocks/rattles are sometimes hard to find (I can remember many times working with my father for hours trying to eliminate rattles on old '60's and '70's vintage Buicks). They can generally be found by rapping, shaking, or wiggling anything that can move. Good luck.
Ulilbastrd
04-20-2003 07:06 AM
Steve's 3.2 TT/Avant
04-09-2003 08:39 AM
$teady$upreme
03-04-2002 09:25 PM
SM
12-30-1999 10:18 PM
