Might have messed up the bearing installation...
It seems like I have a noisy right rear bearing again, and I reflected back to the day when I used my hubshark to press the bearing back in.
The hubshark doesn't seem to have the exact size 'pancake' needed to press the bearing all the way into the knuckle cavity, so I had to use one that was smaller in diameter of the bearing.
See the pretty picture for an explanation. I'm wondering if I effed up the bearing somehow.
I'm sure '77-911 will soon post a pic of the SIR B90.
I wish I would have bought that instead of the hubshark.
<img src="http://www.madisoncomputerservices.com/forum-img/AW/hubshark.jpg">
into the housing. I'm guessing 3 to 4mm.
Here's a couple of pics from Rookie18's gallery. He might have lucked out driving the bearing in with the supplied installer, but mine definitely would NOT go past the knuckle opening. Maybe a manufacturing defect? It wouldn't have to be much wider than 75mm to become a problem..
Rookie18: Sorry for hot-linking, I'll drop the links if you let me know. I'm not sure if you post here anymore?
<img src="http://k41.pbase.com/o4/21/345421/1/56550406.WheelBearingPicturesresize145_4553.jpg">
<img src="http://k43.pbase.com/o4/21/345421/1/56550412.WheelBearingPicturesresize145_4556.jpg">
using a socket the right size and using that in between the hub shark + bearing
yes you might have fudged your bearing
get pressed in too far to remove. In reading another rear bearing article, it looks like you can smack it out with a hammer.. I'll give it a shot.
